mdarien4AQ94
en respuesta a: Pointdump
I sadly can't upload the files directly due to company policy, but I can show the settings I've got and walk through it all.
Below I've snipped the AutoCAD Map 3D settings for MAPIMPORT as well as the Google Earth Pro existing settings.
For the AutoCAD settings, I noticed that the input coordinate system uploads as something different than my current drawing coordinate system. I went through and changed all of these to match the current drawing coordinate system. That import showed the points being within a few hundred feet of where they should be in AutoCAD, but they were still off, and still scaled way off. I went back to Google Earth Pro and got the Lat/Long of 2 points, and I manually added those positions into AutoCAD and scaled. I ended up needing to rotate my points, and that got them very close together but not quite perfect still. There's something off between the actual Lat/Long numbers and what happens to them when importing.
