03-16-2023
04:34 PM
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Suscribirse a un feed RSS
- Resaltar
- Imprimir
- Denunciar
03-16-2023
04:34 PM
IF you absolutely need to measure manually, you'll have to accept the inaccuracies that come with any method/tool you'll use.
The most straightforward method would be to print out a drawing to scale, tape it to a flat screen and measure directly with a ruler..... OK, so that's not the answer you were looking for.
The second best method would be to utilize a proportional divider with a ruler. Set the divider to a known distance in the drawing view and for the scale and once done, you can measure any other distance showing on the screen with a similar accuracy. If you change the view, readjust the divider.
Remember: be careful and not scratch your screen!
