This is the same solution that was given from my google search before posting.  Unfortunately, as you can see in the origional image, the error message takes up the entire window of the Library tab on the blocks pallet.  I do note see or have access to the Icon you're referencing and thus can not remove the file in question causing the "File not found" error.
In short, the error has removed the feature that allows me to clear the error.  I feel like I'm dead in the water.
The ADCENTER is interesting.  I'll take some time to investigate but right now I just need to get through this drawing set and copy pasting between drawings, although sloppy, is getting me through it.
If you have any other suggestions on how I might be able to clear the error I'm all ears.  Thanks again.
