pendean
en respuesta a: garrett_arnold_ext
@garrett_arnold_ext ASAIK you actually have to fix the problem first in that one lower tab to make the error go away, it's never going to do it on its own. From what you keep getting as an error, you've not done that yet or are selecting a source that is never available, and only you can fix that
OR perhaps you need to give up this palette interface, and crack up/startup using ADCENTER command with a much more simplistic user interface that is very user friendly.
