Stephanie_Organ
en respuesta a: Anonymous
I have had the same issues with the missing colour mapping table when trying to convert from .CTB to .STB.
The solution for this is to first use the CONVERTCTB command, and select an existing .CTB plotstyle file. You will then be prompted to save this as a .STB file.
This should give you the colour mapping necessary to now use your desired .STB plot style.
