garrett_arnold_ext
915 Vistas, 6 Respuestas
Blocks Pallet Library Corrupt/File not Found
After uninstalling and re-installing AutoCAD2023 on a Windows 10 Enterprise OS I'm getting an error when trying to access the blocks pallet library from old dwg files.  From what I've seen in the forum here there should be an option to remove libraries that are inaccessible, however I see no option to do so.  The screen has an error where the library options should be (see attached).  I'm copy pasting blocks between documents to get by but that is not a long term solution by any means.
