03-08-2023
06:36 AM
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Suscribirse a un feed RSS
- Resaltar
- Imprimir
- Denunciar
03-08-2023
06:36 AM
Of course you can. There is a command to find and replace text. But the correct method is different:
1. You need to go to the properties of the dwg drawing and create a custom property (_DWGPROPS). For example, name it "Status". However, the standard drawing properties may be enough for you.
2. You need to go to the block editor (_bedit) and in the properties of your attribute, replace the default value with a FIELD referring to the drawing property. The fields are updated automatically. As soon as you change the drawing property, all attributes will immediately replace their values. (You may need to set up automatic field updates)
