pendean
en respuesta a: atuckerJKU9U
@atuckerJKU9U "after a few hours" simply means the culprit is not one you use often.
You can RESET AutoCAD2023, totally resist migrating anything from 2018, and confirm it's not the core program or your files. Then one by one put those add-ins back and test each one.
You'll also need to share screenshots of your ABOUT and GRAPHICSCONFIG commands pop-ups when you post again, and confirm your OS please.
