tboehler
en respuesta a: jdfnnl
Just an FYI.
I'm sure you already know this - you can draw the leader with 3 points.   Allowing you to manually edit the landing (grips or stretch w/text).  Note - this causes much of the standard leader "Linkage" to act differently when moving the landing or text.   Works well if you just need to do this occasionally.  As mentioned - MultiLeaders allow you to set the landing distance.  Cheers!
