jdfnnl
344 Vistas, 6 Respuestas
fine tuning aligned dim
Are there any settings to lengthen this dimension line?
hwood818
en respuesta a: jdfnnl
If you look at the properties of the multileader there should be a landing distance that you can change if you want to only change one leader.
hwood818
en respuesta a: hwood818
Sorry.  You asked about a dimension, not a multileader.  This thread may clarify.
Dimension Landing line shorten - Autodesk Community - Civil 3D
ChicagoLooper
Hello @jdfnnl
Are you referring to that FLAT distance next to 3'-7" in your uploaded image? If you are, it's determined by the:
<<Offset from dim line x 2>>
Go to Dim Style Manager=>Text Tab=>Text Placement section
Chicagolooper
jdfnnl
however there does not seem to be a way of lengthening the landing
pendean
@jdfnnl that's called a landing, and there is no setting for it in DIMSTYLE command. Sorry.
tboehler
Just an FYI.
I'm sure you already know this - you can draw the leader with 3 points.   Allowing you to manually edit the landing (grips or stretch w/text).  Note - this causes much of the standard leader "Linkage" to act differently when moving the landing or text.   Works well if you just need to do this occasionally.  As mentioned - MultiLeaders allow you to set the landing distance.  Cheers!
