fkellogg
en respuesta a: jserjeantson
I use Command: GEOGRAPHICLOCATION Set location from [Map/File]<Map>:
Select "Map"
This brings up a dialog box to enter an address, and you can pan around to where you need to be.
I use the "Road" view, which gives me a very un-cluttered street map view.
I enlarge the window as much as possible, and take a screen shot of it, to paste into Paint and zero in on what I want.
This may not be what you need, but when I found that I could get a clean map without all the Commercial B.S. I was pretty excited, and took the opportunity to share this.
CFKellogg
