02-10-2023
02:43 AM
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Suscribirse a un feed RSS
- Resaltar
- Imprimir
- Denunciar
02-10-2023
02:43 AM
You cannot read .stl files in AutoCAD, you can only export them. Which is basically converting 3D geometry to an .stl file. To read/modify an .stl file you'll need a program such as Fusion360 or Meshmixer. If you desperately want to have the geometry back in AutoCAD you can export it back to a .dwg or .stp from those programs. (a .stp file you can import into AutoCAD with the _IMPORT command)
Fusion360 by Autodesk is available for free for non-professional users.
