kczerwonka
423 Vistas, 8 Respuestas
Window size does not stick
When I run Dimension Style Manager (Command line: '_dimstyle) the window that pops up is too small for me, so I drag the lower right corner diagonally to resize it to my preference. I finish and I close the window (end command). Later, in the same AutoCAD session and DWG, when I execute the Dimension Style Manager command again it has  reverted back to its previous smaller size.
This is always the case with every AutoCAD session and in every DWG that I open.
I want it to keep the larger size that I drag it to.
How can I make it keep the larger size?
Thanks.
