alyssapipolo1
167 Vistas, 2 Respuestas
File corrupt and not functioning when switched view
I have a file that I have be working on solely in 2d wireframe view. I copied a block which I downloaded as a dwg and copyedclip into my file it was distorted into a different perspective from the original. My solution to this was to change my viewport to 3d, shaded view, which I now realize was a huge mistake. When opening the file it is now frozen and not functioning to switch the original viewport properties. I have been unable to recovery the previous version of the file.  If there is anyway to fix this issue or reverse the switch please let me know! Thank you in advance.
paullimapa
en respuesta a: alyssapipolo1
are you able to insert the problem dwg into a new drawing and then explode it?
Paul Li
IT Specialist
@The Office
pendean
How to fix files https://knowledge.autodesk.com/support/autocad/troubleshooting/caas/sfdcarticles/sfdcarticles/AutoCA...
Or you can share it here for others to try if you wish.
