01-26-2023
07:50 AM
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Suscribirse a un feed RSS
- Resaltar
- Imprimir
- Denunciar
01-26-2023
07:50 AM
@merquimanon wrote:
So I make design with multiple sheets (Layouts) and they all use the same Title block. What I am currently doing is manually inputting all the data (Drawn by, Checked by, Plot Scale, etc.) on EVERY single page. I usually takes some time, especially on designs with 10+ pages. I am wondering if there is a way to just change the data in the title block on the first sheet and it automatically change on all the sheets in the sheet set.
XREF your titleblock, then all the static data can be changed in one place and it will reflect throughout.
You can even make the sheet number match the tabname using the field: %<\AcVar ctab>%
