engenzac
296 Vistas, 4 Respuestas
AutoCAD wont open DXF file from Solidworks+Exactflat add-on software
I'm using a software called Exactflat to create drawings of fabric pattern. This software works within Solidworks. When I export, I do so as a Standard DXF. When I go to open in AutoCAD, it tells me to press enter to continue, my file never opens, and it takes me back to the Start screen. Can anyone provide some advice?
[ The subject line of this post has been edited for clarity by @pendean Original: AutoCAD wont open exported DXF file]
Patchy
en respuesta a: engenzac
Check your exported version for Autocad.
pendean
The problem in the DXF file resides with the application(s) that create it: there is literally nothing you can do about it in AutoCAD. Sorry. Ask in those software support areas for help creating AutoCAD-True DXF files, they might have tips you missed.
engenzac
en respuesta a: Patchy
What do you mean exactly?
cadffm
If you like to know what is wrong with the dxf, share a sample.
But there is no setting in Autocad for corrupt data from another software.
Sebastian
