How did you set your scale?
Are you sure your point of view that you are printing is equal to the top view of your drawing. The scaling difference is not proportional across the different dimensions. Which means this is not caused by the scale that you set to print. It is more likely that your view is askew, explaining why the Height difference is not proportional to the Width difference.
Use the viewcube or the command PLAN to set your view back to the top view. I expect you'll have better results.
