Gurkanwal.Dhillon
279 Vistas, 2 Respuestas
Tool Palette's arrangement jumbles up when another user opens it
Background: I'm updating certain blocks in our tool palettes. After making the changes, I put them back in the position they were in, inside the tool palette. Say, I edit the "pipe-tray elevation marker - metric" block, remove the old one, and then place updated block under the "elevation marker" block.
(I cannot right click on the block and edit it because I'm reworking the attributes and you need to do the extra step of deleting and inserting the block)
We have these tool palettes saved on SharePoint, and when another user opens the tool palettes in their AutoCAD, the edited block shows up on the bottom of the list, not under "elevation marker".
Question: Is there a way to lock the arrangement of blocks inside tool palette so I don't have to re-import all the blocks into the tool palette in order to maintain the order.
Appreciate the help!!!
Etiquetas (1)
