merd94
338 Vistas, 3 Respuestas
Can array in dynamic block spread arrayed items and add extra item as the object stretched?
Hello, I am creating a dynamic block (window) and stretching it, and I want to add subdividing elements (arrayed items) to it. I want the arrayed items to be divided evenly across the distance stretched and I want AutoCAD to add an extra object as I pass a specified distance. Is there a way to do it?
For example, the window distance is 550 cm, and the maximum distance for arrayed items I specify as 100 cm, which means there will be 6 arrayed items with a distance between arrayed items 91.6 (from 550/6), however, if I stretch the window to 600 cm AutoCAD should add one more arrayed item, and spread them evenly.
As I have tried everything that I know and searched forums, there is nothing related to this topic. And if there is no such thing, then dear Autodesk can you please add this simple formula to the dynamic blocks and make someone's life easier?
Merd.
Etiquetas (2)
Etiquetas (2)
