JBerns
en respuesta a: Patchy
I would agree with the others that if the interior lines are actually a hatch pattern that is associated to the exterior object (polyline), then the hatch pattern should adjust after the polyline is skewed.
Otherwise, if the interior objects are individual lines, then parametric constraints would be needed to keep them attached to the vertical edges during the skew process.
CAD Administrator
Using Inventor 2022
Autodesk Certified Instructor
Autodesk Inventor 2020 Certified Professional
Autodesk AutoCAD 2017 Certified Professional
