pendean
en respuesta a: nickada
@nickada Got it, you have no suggestions, just a need to seek out easier-to-use DXF/DWG compatible software since you find AutoCAD hard to use.
In which case, you can start here https://knowledge.autodesk.com/support/inventor/troubleshooting/caas/sfdcarticles/sfdcarticles/Impor...
and https://www.google.com/search?q=inventor+tip%3A+how+to+imnort+dxf+files
More tips on how to get the most out of your Inventor software can be discussed here
https://forums.autodesk.com/t5/inventor-forum/bd-p/78
And you can ask for more features here https://forums.autodesk.com/t5/inventor-ideas/idb-p/v1232
Then offer up whatever it is you wish to share about AutoCAD with Autodesk here https://www.autodesk.com/company/contact-us/product-feedback
And might I suggest... try to find easier to use DWG/DXF software here if that online tip offered by others stops working for you
https://all3dp.com/2/best-autocad-alternatives/
https://www.google.com/search?q=alternates+to+autocad
Good luck.
