chakra48
en respuesta a: chakra48
Hi to all,
I am facing another issue. I am using autocad 2012, when i open the file after got opened, it is keep on regen and i could not type command in the command prompt. I recoverd and made audit also. But there is no use. I could not copy into another file bcoz of lots of vp layers and layout setting. Do any one have any lisp to clean the same file itself.  Pls share and it get aborted from autocad Any tool can export all layer settings and import, if we copy into another file. Pls help
