chakra48
1290 Vistas, 11 Respuestas
In my model the polylines are filled but in layout not filled
In my model space the poly lines are filled but when my paper space its not filled. I solved the problem using plan and current ucs. All my vp settings gone and layout gone. Without doing plan and current ucs, is there anyother to come of this issue. here i attached file. Pls help me is there any shortcut method to show the polyline filled in model and layout
pendean
en respuesta a: chakra48
Your viewport's "custom view" is the culprit, replacing it with TOP fixes the issue
dbroad
You have correctly diagnosed that the viewport direction is wrong for a plan view.  You should certainly unlock the viewport and set the ucs to world.  Doing the plan command will automatically zoom to extents unfortunately so this may help.  Paste the following into your command line, while in the layout and in paper space and after unlocking the viewport.
(vla-put-direction (vlax-ename->vla-object(car(entsel "\nSelect Viewport: "))) (vlax-3d-point '(0 0 1)))
Architect, Registered NC, VA, SC, & GA.
chakra48
en respuesta a: dbroad
Thanks for the reply. But the following error
Command: (vla-put-direction (vlax-ename->vla-object(car(entsel "\nSelect
Select Viewport: ; error: no function definition: VLAX-ENAME->VLA-OBJECT
chakra48
en respuesta a: pendean
Thanks for the update. I unlocked the viewport, i can enable to select "TOP", BUT AFTER THAT EVERTHING GONE TO MODEL SPACE. I CANT SET THE VP LAYERS AGAIN AND LAYOUT TOO, TAKES LOT OFF TIME. IS THERE ANY SORTCUT, SORRY TO DISTURB YOU, I AMTOTALLY UPSET BCOZ OF MY SUBMISSION
JBerns
@chakra48 ,
You need to load the Visual LISP tools before performing a Visual LISP function.
At Command prompt, type:
(vl-load-com)
Jerry
CAD Administrator
Using Inventor 2022
Autodesk Certified Instructor
Autodesk Inventor 2020 Certified Professional
Autodesk AutoCAD 2017 Certified Professional
chakra48
en respuesta a: JBerns
Dear jberns,
   Thanks a lot. You have saved my time and i am fully relieved my hectic situation. Once again Thanks a lot
JBerns
@chakra48,
You're welcome, but the Solution credit should go to  @pendean and @dbroad .
Jerry
CAD Administrator
Using Inventor 2022
dbroad
Agreed. Thanks
chakra48
Hi to all,
  I am getting another issue, it keep on generating and I could not enter command. Version 2012 using. I tried recovered and off auto-generated and getting aborted. Even though I have Dell G3 system. Any lisp to recover and clean the stuff. Only this file.
pendean
@chakra48 Restart your PC to resolve it: you also need to ensure your old AutoCAD 2012 is fully updated https://knowledge.autodesk.com/support/autocad/troubleshooting/caas/downloads/content/autocad-2012-s...
Note that old AutoCAD 2012 is not supported in Win11 nor Win10, if that is the real problem for your regen looping, there is no fix. You are out of luck. DellG3 has no bearing on much of anything you are reporting sadly.
chakra48
Hi to all,
I am facing another issue. I am using autocad 2012, when i open the file after got opened, it is keep on regen and i could not type command in the command prompt. I recoverd and made audit also. But there is no use. I could not copy into another file bcoz of lots of vp layers and layout setting. Do any one have any lisp to clean the same file itself.  Pls share and it get aborted from autocad Any tool can export all layer settings and import, if we copy into another file. Pls help
