pendean
en respuesta a: akeic
@akeic wrote:
I had the same issue of CAD freezing as the OP, so I went ahead and reset factor settings based on the link provided. This solved the issue of the DGN export, but I want to get my settings back.
I chose to backup my current settings, but now I cannot restore those settings from the zip folder. The zip folder cannot be unzipped and appears to contain zero files.
Any advice?
Thanks!
If you backed up your customizations like this
Then restoring them (assuming the ZIP file was created correctly and you did not change year-versions) is like this
Burt sometimes, as rare as it often is, what you think worked did not and you'll need to start over if you never backed up your setup ever before to a safe place to try (even if it is older). Sorry, it happens.
