pendean
en respuesta a: merav1
Greetings @merav1
A DWG file is either set to use CTB or STB, never both: perhaps the file you are open is only set to use STB? CONVERTPSTYLES command as explained in HELP would be the fix. Just like in AutoCAD2018.
OR... you forgot to move your custom CTBs from 2018 to 2023: that rarely happens by magic on it's own sadly.
OR... you can explore the very long list of things to try in the post from Autodesk Support https://knowledge.autodesk.com/support/autocad/troubleshooting/caas/sfdcarticles/sfdcarticles/Error-...
HTH
