AUTODESK EXPERT ELITE
1814 Kudos
1258 Solutions
Re: DELETE and SAVEAS extremely slow compared to 2012
01-29-2013 07:35 AM in reply to: bryce.thelin
@Bryce
>> Probably the best workaround though is to set your DWF file format to 2010
That's the first time I get the info that saving back to an older release makes saving faster. I can't believe that (under normal cicumstances).
@Ixath
>> I believe it's a vertical product? It's AutoCAD MEP 2013
Yes, MEP is a vertical product. You might search in the >>>forum for MEP<<<, maybe there are people having the same problem or maybe you find some hints for your situation.
Good luck, - alfred -
Alfred NESWADBA
Ingenieur Studio HOLLAUS ... www.hollaus.at
