12-17-2022
07:26 AM
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Suscribirse a un feed RSS
- Resaltar
- Imprimir
- Denunciar
12-17-2022
07:26 AM
That would be a flaw in the conversion tool/method you used I suspect. Is manually fixing it in AutoCAD not an option? Using a different conversion tool(s) would be the other things to try.
May I ask, are you using the RASTERDESIGN add-on in AutoCAD to help? It is free to install and use for anyone in an active subscription of AutoCAD. it's not a conversion tool per-se, but it is a different way to incorporate images into DWG files and use/fix where needed.
