cadffm
en respuesta a: GD.ON
1. No, you can not change it.
2. It has nothing to do with the ucs and ucs origin
3. You wouldn't have a problem with the pagesetup(change of papersizes)
   if you would use the way I use it always.
 My Layout is clean, only one frame and nothing outside!
 My frames are designed the way I can use Plot area = Extents / centered!
And you never need to change anything, anymore.
It sounds you are using Window or the worst choice Layout as Plot area..
Sebastian
