12-13-2022
05:30 AM
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Suscribirse a un feed RSS
- Resaltar
- Imprimir
- Denunciar
12-13-2022
05:30 AM
Not every AutoCAD feature works for every single user: so... your concerns are heard and not judged over here.
Looks like your block already contain those undesired definitions based on your post: there is no "Autodesk is forcing you do do it this way" stuff in the program, you the user are in full control pretty much all the time (unless Autodesk really removes a feature you like).
What all that means is you will need to edit each and every one of your source blocks to remove all that you wish to never see, then in each final destination file you will need to PURGE or if in use then CHECKSTANDARDS those unwanted into oblivion.
You appear to have a lot of house-cleaning to do up front to get the final results you desire.
If you suspect otherwise, pleas elaborate in more detail and share source dwg block files and destination DWG files for others to examine around here.
HTH
HTH
