dany_rochefort
en respuesta a: totaltext
@totaltext Setting your new autocad workspace up in ''Classic Mode with a Menubar''  will go a long way in making feel in a similar 1992 environment. Nowadays Autocad uses all sorts of Ribbons, Tiles, Toolpallets and stuff for commands. The classical small button icons from the 1990's are still available and widely used.  User interface customization HAS changed alot.However, the commands have evolved along the same baseline that you were taught in the 1990's.
The setup i use these days does remind me of older setup. The reason for choosing this type of interface is the optimize drafting space while reducing the space taken up by the icons.
With a bit of work you can get your 2023 autocad to look like this, but more shinnier...
