340 Vistas, 6 Respuestas
Plotting issue
When I plot a drawing from my computer using AutoCAD 13 with the plot style as monochrome, the plot is not usable - cannot read.  Taking the same drawing on another computer in our office using all of the same settings and AutoCAD 13, the plot looks like it should.  If I use another company wide plot style the same thing happens.
Suggestions on where the problem might be.
pendean
en respuesta a: Anonymous
What does "cannot read" mean? Show us a PDF output for example.
What does "same thing happens", is that a good plot or a bad plot?
Also share with us your fully expanded PLOT pop-up screenshot for us to see what's else is set/no set.
Attached are 2 drawings in one PDF file. One drawing is good the other drawing is not good.
The drawings were printed on different computers to the same printer. The same plot style was used on both computers. AutoCAD 13 Version G204.0.0.AutoCAD 2013 SP2.
Also, the drawings look like those attached when using the monochrome plot style.
Let me know if you need more info.
David Helfrich
Pany & Lentz Engineering Co.
609 Hamilton Street
Allentown, PA 18101
Phone: 610 433-1634
Fax: 610 433-1636
dhelfrich@plec.us
pendean
Nothing attached.
en respuesta a: pendean
I did attach but the size was over 1MB.  I resized the PDF and attached.
pendean
Those look like old school stick fonts (SHX) with no line weights assigned: it also looks like a plot of an image from inside AutoCAD.
This did not help.  Please cancel this topic until I have a better explanation of what is happening when I print. This issue seems to be related to only one drawing file.  I will monitior future drawing files to see if same or similar issues occur and respond with a new message.
