cadffm
en respuesta a: 803007527
Try this:
command: (getvar "dimlayer")
What is the feedback? It should be "."
Try this
command: (setvar "dimlayer" ".")
and create a dimension by type in
command: DIMLINEAR
still "use current" ?
If yes: " upgraded from autocad 2014 to 2022"
and you used the "migration from older version" feature?
Use the "Reset to default" option and answer the first question with YES (save the current settings).
https://knowledge.autodesk.com/support/autocad/learn-explore/caas/sfdcarticles/sfdcarticles/How-to-r...
Restart the program and DO NOT migrate anyting.
Try it again: Dimlinear..
Sebastian
