chincock
en respuesta a: cadffm
@cadffm
Thanks. I can produce the right result with your help in post 12.
It seems that I have found where the issue is. Since in my original operation of the DE process on its page 6, I don't want the counter and name columns so I deselect the last two options. However, during these deselections the DE automatically resorts the data with respect to the first column, leading to this issue. You can try whether it will reproduce or not.
Furthermore, when the aforementioned automatical resort is triggered, you have to click the "column resort option" button and directly click on the OK button without any change in that window, then the data change back to their default order. Really confused.
