12-05-2022
04:37 AM
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Suscribirse a un feed RSS
- Resaltar
- Imprimir
- Denunciar
12-05-2022
04:37 AM
@cadffm wrote:
Of course
but it has nothing to do with the dataextract command, your export informations are right!
Your points in DWG are wrong IF the spline is correct.
We can not check the spline and we can not check the divide result, because don't have your spline
I checked the order of the points before. It's correct.
The issue is definitely about the DXE process. Wrong (manual) selection, manually sorted, or... the bug.
@chincock do you get the wrong result if you let the DXE to export that automatically? No user interference. All points, no sorting.
