cadffm
en respuesta a: chincock
>>"Most of the coordinates are correct except for several points. The incorrect data locate between the 304 and 306 of the X-coordinate,"
No, ALL data are correct!
>>"the Y-coordinate should be monotonically increasing rather than fluctuating."
Check the data for the point where your eyes on and you will see the " monotonically increasing".
>>"The .dwg file is attached. Please also kindly check the screenshot.2
Thanks, the best way to share informations, digital data :cara_con_una_leve_sonrisa:
>>"This issue is also presented in the latest 2023 version of AutoCAD. The OS is Windows 11 22H2 x64."
I can't see any issue, but I think your problem is: You expect the points in a special order,
the creation order of the POINTs!
But your DXE is set up to use another order, the X-Pos value as Order)
If you used "object selection" method, you selected the wrong way.
If you used the option to exytract the whole drawing, you changed the order on page5
Sebastian
