- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Suscribirse a un feed RSS
- Resaltar
- Imprimir
- Denunciar
These days I meet a very annoying issue when using dataextraction. I have drawn a B-spline line and divided it into 2000 segments. Then, I am using dataextraction to export all the coordinates of the segments. Most of the coordinates are correct except for several points. The incorrect data locate between the 304 and 306 of the X-coordinate, in which many coordinates don't belong to the B-spline are also extracted. In this region, the Y-coordinate should be monotonically increasing rather than fluctuating. The .dwg file is attached. Please also kindly check the screenshot.
This issue is also presented in the latest 2023 version of AutoCAD. The OS is Windows 11 22H2 x64.
I very much appreciate it if you can give any help.
[ The subject line of this post has been edited for clarity by @handjonathan Original: dataextraction bug ]
¡Resuelto! Ir a solución.
