TheCADnoob
en respuesta a: czegee
A quick 'no code' way to get this done is to use your xls to create a formula and then paste the formula(s) into the command line.
In this example, I added a column to excel for the file destination. Then I used the following formula in excel
=CONCAT("CIRCLE 0,0 ", A2," CIRCLE 0,0 ",B2," -TEXT 0,0 5 0 ",C2,"
filedia 0 DXFOUT ",D2," ",A2,"-",B2,"-",C2,".DXF
16
Select All
Erase
Filedia 1")
Then copy all those resulting formula strings into notepad in order to get rid of the extra quotation marks. (ctrl + H for find and replace)
Then paste all that data into the command line. This creates and saves the files and you are done.
It should be noted that tailoring this can be a little tedious
so if you make any changes it can be a lot of guess and check. but once you get it, its solid and quick.
CADnoob
