01-13-2016
10:12 AM
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Suscribirse a un feed RSS
- Resaltar
- Imprimir
- Denunciar
01-13-2016
10:12 AM
>> In HydraCAD, to check to make sure your pipes and heads are connected and
>> elevate to the right height, I have a command to elevate up in 3D
Do I understand that correct, this is a HydraCAD command, and after this command is finished lines disappeared?
And the developer of that application tells you it's AutoCAD's fault that lines disappear after running a HydraCAD command? That would be strange ...
- alfred -
Alfred NESWADBA
(not an Autodesk consultant)
Alfred NESWADBA
