PamelaEdwards
335 Vistas, 2 Respuestas
AutoCAD 2023 - How to unlock layers in a new Sheet Set
I created a new Sheet Set in SSM based on an existing Sheet Set in Autocad 2023.
The drawing I used was a 'saved as' of the drawing I used for the existing Sheet Set.
The layout tabs are basically the same in both drawings except for the
When I imported layouts into the new sheet set, they are locked.
Please see the following:
How do I unlock them?
Thank you for your time.
[ The subject line of this post has been edited for clarity by @handjonathan Original: How to unlock layers in a new Sheet Set ]
3wood
en respuesta a: PamelaEdwards
I used to copy the whole folder which contains the dwg files and the dst file into a new folder.
PamelaEdwards
en respuesta a: 3wood
I will try that. Thank you
