sander.van.pelt
439 Vistas, 3 Respuestas
AutoCAD - Incomplete attached PDF after plot
Hello everybody,
I have a problem plotting a drawing. In this drawing I attached/ imported a PDF with a floorplan with a HVAC installation, and, at the right side of this PDF a renvoy, unit list and a stamp drawing (A4 size/ 210mm wide).
I use this pdf together with a new architectural floor plan (dwg) as xref.
This new architectural floor plan is located above the PDF so that all deviations are clearly visible.
Now everything is clearly visible on the imported PDF. When I create a layout, everything is visible as it should be.
If I now print a new drawing, on paper or as PDF, then the entire right side of the imported PDF with stamp etc. has disappeared and I also miss texts almost everywhere on the new PDF drawing. Attributes of blocks, dimensions of pipes and air ducts.
Some have completely disappeared but some are partly there, for example a dimensioned air duct of "400x250" mm now reads "4 x 50". It is not the same numbers / letters everywhere that have been lost.
Does anyone have an idea what could be causing this?
In my model and layout of the drawing everything is displayed correctly. This is also the case in the plot preview.
Then why not on the plot?
[ The subject line of this post has been edited for clarity by @handjonathan Original: Incomplete attached PDF after plot ]
Etiquetas (2)
