11-05-2022
05:38 PM
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Suscribirse a un feed RSS
- Resaltar
- Imprimir
- Denunciar
11-05-2022
05:38 PM
The plugin mentioned by BeekeeCZ is free and is the easiest solution for making an xref unselectable.
Xref Tools Extra - Free plugin from Autodesk store
Follow these steps:
1. Install the plugin
2. Close AutoCAD (if open), and relaunch
3. You will be prompted to allow/disallow the new add-in to load. I would suggest choosing 'Always Load'. This pop-up should not occur again for you.
4. Once your drawing is open, run XREFI command which opens up the window shown below.
5. Enable the Show, Snappable, Selectable options checkbox.
6. Unselect the Selectable checkbox next to the xref you would like to make unselectable.
That's all there is to it!
