czegee
535 Vistas, 1 Respuesta
AutoCAD - Generate dxf files based on xls or txt
Hello!
I have a material drawing for plasma cutting. I want to put a text on this material (which will be engraved), and save all the possible outcomes in different files.
Is there a way to do this somehow?
the absolute dream would be if it could have been done by an xls, where every row would be a separate file.
The most important is only the text, but if other paramteres can be included that would be perfect.
Specific example:
D1= 1000
D2 = 30
Text = Test
D1 would be diamater1 D2 would be diameter2 and text would be the desired engraved text in my xls, and every row would be a different dxf file. The most important for me only the text, if the others not possible thats not a problem.
Thanks for your reply in advance
[ The subject line of this post has been edited for clarity by @handjonathan Original: generate dxf files based on xls or txt ]
Etiquetas (4)
