PhilvK
3050 Vistas, 14 Respuestas
Measure Distance Between 2 Points
I just upgraded from Acad 2018 to 2023. How do you measure the distance between 2 points in v2023? The measure tool under the draw panel doesn't allow me to pick 2 points as in previous versions.
whitney_jeff
en respuesta a: PhilvK
Try DI or DIST
Measure is for placing points or blocks at specified spacing along an object
user181
Try the measure on the Utilities panel on the right of the ribbon. Click the down arrow and there are several options
imadHabash
  • MEASURE command .. Creates point objects or blocks at measured intervals along the length or perimeter of an object. >> Click <<
  • MEASUREGEOM command .. Measures the distance, radius, angle, area, and volume of selected objects, a sequence of points, or dynamically. >> Click <<
  • DIST command .. Measures the distance and angle between two points. >> Click <<
Imad Habash
PhilvK
en respuesta a: user181
user181 - I seemed to have lost my Utilities menu
PhilvK
en respuesta a: whitney_jeff
Jeff - Thank you..DI works
PhilvK
Jeff - Thank you...DI works
pendean
Right click in an empty spot on the ribbon, then find and turn on that missing panel
whitney_jeff
Mark as accepted please
PhilvK
en respuesta a: pendean
I tried the right-clicking but see 'Utilities' or anything like it.
PhilvK
Oops
PhilvK
I DON'T see Utilities
user181
Utilities is in the Drafting and Annotation Workspace. Maybe you are currently using a different workspace and would need to switch to see it.  From your image looks like you are in the 3D modeling workspace.
pendean
PhilvK
Bingo! That did it. Thanks.
