- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Suscribirse a un feed RSS
- Resaltar
- Imprimir
- Denunciar
This only happens with clipped (polygonal) viewports.
When I click to select the viewport and want to view or edit using the properties box, it shows that I have a polygon selected, and I have no viewport properties available. When I use a drag box to select the same viewport, it works properly and I can view and edit properties.
This has recently started happening on all of my drawings. I was wondering if this is a setting, or a problem in the files.
Windows 10
Autocad 2022.1.2
Thanks!
[ The subject line of this post has been edited for clarity by @handjonathan Original: Selecting viewports ]
¡Resuelto! Ir a solución.
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
- Denunciar
The Polyline (or cicle, or region..) is the Viewport clip-object (because a viewport object is always rectangle,
it is only possible to "VPCLIP" it.
Q: Check the SELECTIONCYCLING feature, is it ON on one machine and OFF on the other one?
Sebastian
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
- Denunciar
see if it makes a difference by updated to 2022.1.3
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
- Denunciar
