21-07593
337 Vistas, 2 Respuestas
AutoCAD - Why does my circle keep turning into cylinders
I am trying to make a simple circle in AutoCAD but at one point there was something weird with the fillet tool so I tried to look at it from a different angle and I discovered that whenever I draw circles it makes cylinders. it just suddenly happened one day. This only happens to circles and not the rectangle tool.Making a normal circleMaking a normal circleThis is what happens. I did not specify this height, it just does thisThis is what happens. I did not specify this height, it just does this
[ The subject line of this post has been edited for clarity by @handjonathan Original: Why does my circle keep turning into cylinders ]
user181
en respuesta a: 21-07593
Maybe you have a value set for THICKNESS. Enter it at the command line and set it to 0
en respuesta a: user181
Oh, you're right. Thanks, didn't know when this value was changed but setting it to 0 completely fixes the issue.
