cheryl.buck
en respuesta a: stefano.avanzo
Hi @stefano.avanzo,
Thank you for getting back to me. That is correct, 3D solids cannot be exploded. That command was suggested as an initial step to separate the solids from the block.
To create a 2D from these solid objects, you will want to use the FLATSHOT command mentioned in my last post. This will create a block reference with 2D geometry, which can then be exploded for your other program if it cannot work with blocks.
All the best,
Cheryl Buck
Technical Support Specialist
Did a post answer your question or help resolve the issue? Please click the Accept Solution button.
If you find a response helpful, consider Liking the post.
