pendean
en respuesta a: mathewbailey08
SketchUp if fabulously easy to use and master.
AutoCAD is not.
Both have the same abilities to output similar results in the end.
So, are you hoping for ease of use (AutoCAD is not there), or are you willing to roll up your sleeves for a learning curve ahead of output (worth it ultimately if you honestly cannot afford SketchUp's $299/yr for some reason)?
Buy the way, check this current-freeware for a possible third option https://www.bricsys.com/en-ae/bricscad-shape
TIA
