cheryl.buck
en respuesta a: stefano.avanzo
Hi @stefano.avanzo,
It sounds like your program needs 2D objects, so EXPLODE was the right choice if the blocks contained 2D. For blocks that contain 3D objects, they will still need to be exploded, then the FLATSHOT (Command) may work well for you.
All the best,
Cheryl Buck
Technical Support Specialist
Did a post answer your question or help resolve the issue? Please click the Accept Solution button.
If you find a response helpful, consider Liking the post.
