yairMSKTU
259 Vistas, 1 Respuesta
AutoCAD - is purge command has anything to do with xrefs ?
does purge command is affected by the xrefs ?           (obviously it wont purge the xrefs .dwg itself)
if i purge my drawing,  and blocks or materials or other stuff are in loaded/unloaded/unreferenced/cant be found xrefs,  would it change the purge results ?
[ The subject line of this post has been edited to include the product name by @handjonathan ]
imadHabash
en respuesta a: yairMSKTU
The answer is NO .. Purge command  Removes unused items, such as block definitions and layers, from the drawing. These include block definitions, dimension styles, groups, layers, linetypes, and text styles. Zero-length geometry, empty text objects, and orphaned DGN linestyle data can also be removed.
Imad Habash
