jdfnnl
en respuesta a: pendean
@pendean wrote:
Correct, that is a pointless option for any user that wishes to be productive in AutoCAD.
Not sure how this statement is valid with so many different styles of using AutoCAD, exemplified by the extensive customizability of the user interface.
The only other way of changing the active layer with the keyboard I know of involves specifying the complete layer name (-la > s > 'layer name'), which seems more involved that a simple hotkey to the layer control drop-down before using the arrow keys to select, then <enter>. Macros may be a workaround, but this would need be an external script as AutoCAD CUI doesn't natively support macros for control entries.
This Autodesk help entry shows a button from the Mechanical Toolset pointing to a command with this functionality. Also read of a right click menu entry for 'move to layer' that brings up a window, but was this possibly implemented in a recent version of AutoCAD? Does anyone have a preferred method of changing the active layer with the keyboard?
